Sun Cluster Data Services Planning and Administration Guide for Solaris OS
How to Recover From a Fault After Modifying an HAStoragePlus Resource
If a fault occurs during a modification of the FileSystemMountPoints extension property, the status of the HAStoragePlus resource is online and faulted. After the fault is corrected, the status of the HAStoragePlus resource is online.
  1. Determine the fault that caused the attempted modification to fail.
    # scstat -g
    The status message of the faulty HAStoragePlus resource indicates the fault. Possible faults are as follows:
    • The device on which the file system should reside does not exist.
    • An attempt by the fsck command to repair a file system failed.
    • The mount point of a file system that you attempted to add does not exist.
    • A file system that you attempted to add cannot be mounted.
    • A file system that you attempted to remove cannot be unmounted.
  2. Correct the fault that caused the attempted modification to fail.
  3. Repeat the step to modify the FileSystemMountPoints extension property of the HAStoragePlus resource.
    # scrgadm -c -j hasp-resource -x FileSystemMountPoints="mount-point-list"
    -j hasp-resource
    Specifies the HAStoragePlus resource that you are modifying
    Specifies a comma-separated list of mount points that you specified in the unsuccessful attempt to modify the highly available file system
  4. Confirm that the HAStoragePlus resource is online and not faulted.
    # scstat -g
Example 2–5 Status of a Faulty HAStoragePlus Resource
This example shows the status of a faulty HAStoragePlus resource. This resource is faulty because an attempt by the fsck command to repair a file system failed.
# scstat -g
 -- Resource Groups and Resources --
             Group Name      Resources
  Resources: rghasp          rshasp
 -- Resource Groups --
             Group Name      Node Name    State
      Group: rghasp          node46       Offline
      Group: rghasp          node47       Online
 -- Resources --
           Resource Name   Node Name    State   Status Message
 Resource: rshasp          node46       Offline Offline
 Resource: rshasp          node47       Online  Online Faulted - Failed
to fsck: /mnt.
