Become superuser on a cluster member.
Enable the resource fault monitor.
# scswitch -e -M -j resource |
Enables a resource or resource monitor.
Enables the fault monitor for the specified resource.
Specifies the name of the resource.
Verify that the resource fault monitor has been enabled.
Run the following command on each cluster node, and check for monitored fields (RS Monitored).
# scrgadm -pv |
This example shows how to enable a resource fault monitor.
# scswitch -e -M -j resource-1 # scrgadm -pv ... RS Monitored: yes... |
