Sun Cluster Data Services Planning and Administration Guide for Solaris OS
How to Set Up an RGOffload Resource
  1. Become superuser on a cluster member.
  2. Determine whether the RGOffload resource type is registered.
    The following command prints a list of resource types.
    # scrgadm -p|egrep SUNW.RGOffload
  3. If needed, register the resource type
    # scrgadm -a -t SUNW.RGOffload
  4. Set the Desired_primaries to zero in each resource group to be offloaded by the RGOffload resource.
    # scrgadm -c -g offload-rg -y Desired_primaries=0
  5. Add the RGOffload resource to the critical failover resource group and set the extension properties.
    Do not place a resource group on more than one resource's rg_to_offload list. Placing a resource group on multiple rg_to_offload lists may cause the resource group to be taken offline and brought back online repeatedly.
    See Configuring RGOffload Extension Properties for extension property descriptions.
    # scrgadm -aj rgoffload-resource \
    -t SUNW.RGOffload -g critical-rg \
    -x rg_to_offload=offload-rg-1, offload-rg-2, ... \
    -x continue_to_offload=TRUE \
    -x max_offload_retry=15
    Note –
    Extension properties other than rg_to_offload are shown with default values here. rg_to_offload is a comma-separated list of resource groups that are not dependent on each other. This list cannot include the resource group to which the RGOffload resource is being added.
  6. Enable the RGOffload resource.
    # scswitch -ej rgoffload-resource
  7. Set the dependency of the critical failover resource on the RGOffload resource.
    # scrgadm -c -j critical-resource \
    -y Resource_dependencies=rgoffload-resource
    Resource_dependencies_weak may also be used. Using Resource_dependencies_weak on the RGOffload resource type will allow the critical failover resource to start up even if errors are encountered during offload of offload-rg.
  8. Bring the resource group to be offloaded online.
    # scswitch -z -g offload-rg, offload-rg-2, ... -h [nodelist]
    The resource group remains online on all nodes where the critical resource group is offline. The fault monitor prevents the resource group from running on the node where the critical resource group is online.
    Because Desired_primaries for resource groups to be offloaded is set to 0 (see Step 4), the “-Z” option will not bring these resource groups online.
  9. If the critical failover resource group is not online, bring it online.
    # scswitch -Z -g critical-rg
SPARC: Example – Configuring an RGOffload Resource
This example describes how to configure an RGOffload resource (rgofl), the critical resource group that contains the RGOffload resource (oracle_rg), and scalable resource groups that are offloaded when the critical resource group comes online (IWS-SC, IWS-SC-2). The critical resource in this example is oracle-server-rs.
In this example, oracle_rg, IWS-SC, and IWS-SC-2 can be mastered on any node of cluster “triped”, phys-triped-1, phys-triped-2, phys-triped-3.
[Determine whether the SUNW.RGOffload resource type is registered.]
[If needed, register the resource type.]
[Set the Desired_primaries to zero in each resource group to be
offloaded by the RGOffload resource.]
# scrgadm -c -g IWS-SC-2 -y Desired_primaries=0
# scrgadm -c -g IWS-SC -y Desired_primaries=0
[Add the RGOffload resource to the critical resource group and set
the extension properties.]
# scrgadm -aj rgofl -t SUNW.RGOffload -g oracle_rg \
-x rg_to_offload=IWS-SC,IWS-SC-2 -x continue_to_offload=TRUE \
[Enable the RGOffload resource.]
# scswitch -ej rgofl
[Set the dependency of the critical failover resource to the RGOffload resource.]
# scrgadm -c -j oracle-server-rs -y Resource_dependencies=rgofl
[Bring the resource groups to be offloaded online on all nodes.]
# scswitch -z -g IWS-SC,IWS-SC-2 -h phys-triped-1,phys-triped-2,phys-triped-3
[If the critical failover resource group is not online, bring it online.]
# scswitch -Z -g oracle_rg
