Sun Cluster Geographic Edition System Administration Guide
Preface
Sun Cluster Geographic Edition System Administration Guide provides procedures for administering SunTM Cluster Geographic Edition software. This document is intended for experienced system administrators with extensive knowledge of Sun software and hardware. This document is not to be used as a planning or presales guide.
The instructions in this book assume knowledge of the SolarisTM Operating System (Solaris OS), of Sun Cluster, and expertise with the volume manager software that is used with Sun Cluster software.
Note –
This release of Sun Cluster Geographic Edition supports the following releases of Sun's availability suite software:
In this manual, references to Sun StorageTekTM Availability Suite software also apply to Sun StorEdgeTM Availability Suite software unless specifically stated otherwise.
Related Documentation
Information about related Sun Cluster Geographic Edition topics is available in the documentation that is listed in the following table. All Sun Cluster Geographic Edition documentation is available at http://docs.sun.com.
Topic
Documentation
Overview
Sun Cluster Geographic Edition Overview
Sun Cluster Geographic Edition 3.2 1/09 Documentation Center
Installation
Sun Cluster Geographic Edition Installation Guide
Data Replication
Sun Cluster Geographic Edition Data Replication Guide for EMC Symmetrix Remote Data Facility
Sun Cluster Geographic Edition Data Replication Guide for Hitachi TrueCopy
Sun Cluster Geographic Edition Data Replication Guide for Oracle Data Guard
Sun Cluster Geographic Edition Data Replication Guide for Sun StorageTek Availability Suite
System administration
Sun Cluster Quick Reference
Information about related Sun Cluster topics is available in the documentation that is listed in the following table. All Sun Cluster documentation is available at http://docs.sun.com.
Topic
Documentation
Overview
Sun Cluster Overview for Solaris OS
Sun Cluster 3.2 1/09 Documentation Center
Concepts
Sun Cluster Concepts Guide for Solaris OS
Hardware installation and administration
Sun Cluster 3.1 - 3.2 Hardware Administration Manual for Solaris OS
Individual hardware administration guides
Software installation
Sun Cluster Software Installation Guide for Solaris OS
Sun Cluster Quick Start Guide for Solaris OS
Data service installation and administration
Sun Cluster Data Services Planning and Administration Guide for Solaris OS
Individual data service guides
Data service development
Sun Cluster Data Services Developer’s Guide for Solaris OS
Sun Cluster System Administration Guide for Solaris OS
Software upgrade
Sun Cluster Upgrade Guide for Solaris OS
Error messages
Sun Cluster Error Messages Guide for Solaris OS
Command and function references
Sun Cluster Reference Manual for Solaris OS
Sun Cluster Data Services Reference Manual for Solaris OS
Sun Cluster Quorum Server Reference Manual for Solaris OS
For a complete list of Sun Cluster documentation, see the release notes for your release of Sun Cluster Geographic Edition software at http://wikis.sun.com/display/SunCluster/Home/.
Related Third-Party Web Site References
Sun is not responsible for the availability of third-party web sites mentioned in this document. Sun does not endorse and is not responsible or liable for any content, advertising, products, or other materials that are available on or through such sites or resources. Sun will not be responsible or liable for any actual or alleged damage or loss caused or alleged to be caused by or in connection with use of or reliance on any such content, goods, or services that are available on or through such sites or resources.
Using UNIX Commands
This document contains information about commands that are used to install, configure, or administer a Sun Cluster Geographic Edition configuration. This document might not contain complete information on basic UNIX® commands and procedures such as shutting down the system, booting the system, and configuring devices.
See one or more of the following sources for this information:
Documentation, Support, and Training
The Sun web site provides information about the following additional resources:
Obtaining Help
If you have problems installing or using Sun Cluster Geographic Edition software, contact your service provider and provide the following information:
Use the following commands to gather information about each node on your system for your service provider.
Command
Function
prtconf -v
Displays the size of the system memory and reports information about peripheral devices
psrinfo -v
Displays information about processors
showrev –p
Reports which patches are installed
prtdiag -v
Displays system diagnostic information
geoadm -V
Displays the Sun Cluster Geographic Edition software release information
cluster status
Provides a snapshot of the cluster status
cluster show
Lists cluster configuration information
geoadm status
Displays the Sun Cluster Geographic Edition runtime status of the local cluster
Also have available the contents of the /var/adm/messages file.
Typographic Conventions
The following table describes the typographic conventions that are used in this book.
Table P–1 Typographic Conventions
Typeface
Meaning
Example
AaBbCc123
The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
AaBbCc123
What you type, contrasted with onscreen computer output
machine_name% su
Password:
aabbcc123
Placeholder: replace with a real name or value
The command to remove a file is rm filename.
AaBbCc123
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
A cache is a copy that is stored locally.
Do not save the file.
Note: Some emphasized items appear bold online.
Shell Prompts in Command Examples
The following table shows the default UNIX system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts
Shell
Prompt
C shell
machine_name%
C shell for superuser
machine_name#
Bourne shell and Korn shell
Bourne shell and Korn shell for superuser
