Name | Description | Attributes | See Also
Defines how entries are compressed.
Valid values |
none and DSZ |
Default value |
none |
Is readable |
Yes |
Is modifiable |
Yes |
Is multi-valued |
No |
Restart needed |
No |
none — No entries compression mechanism will be used.
DSZ — Entries will be compressed using the DSZ method.
Entries compressed are defined by compressed-entries.
$ dsconf set-suffix-prop —p port-number dc=example,dc=com compression-mode:DSZ |
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
