Name | Description | Attributes | See Also
Syntax |
integer |
Default value |
unlimited |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximun number of operations, allowed by the connection handler, per interval of time. The interval of time is defined by the property: op-count-per-interval-timeout(5dpconf).
This property takes an integer.
The value of this property must be at least 1.
The default behavior for this property is as follows: Feature is disabled
This property is used to configure the following features:
Resource limit policies define the maximum resources that Directory Proxy Server can process for a given connection handler.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
