Name | Description | Attributes | See Also
Syntax |
string |
Default value |
objectclass |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the attribute used by VLV control to sort results.
The syntax of this string is ATTR_NAME.
The value of this property must match the pattern ^[a-zA-Z][-a-zA-Z0-9]*$.
This property is used to configure the following features:
A join data view is an aggregation of multiple data views. The current release of Directory Proxy Server supports the aggregation of two data views into one join data view.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
