Solaris Naming Administration Guide
Syntax for Access Rights
This subsection describes the access rights syntax used with the various NIS+ commands that deal with authorization and access rights.
Class, Operator, and Rights Syntax
Access rights, whether specified in an environment variable or a command, are identified with three types of arguments: class, operator, and right.
Table 9-7 Access Rights Syntax--Class
Class
Description
n
Nobody: all unauthenticated requests
o
The owner of the object or table entry
g
The group owner of the object or table entry
w
World: all authenticated principals
a
All: shorthand for owner, group, and world (this is the default)
Table 9-8 Access Rights Syntax--Operator
Operator
Description
Adds the access rights specified by right
Revokes the access rights specified by right
Explicitly changes the access rights specified by right; in other words, revokes all existing rights and replaces them with the new access rights.
Table 9-9 Access Rights Syntax--Rights
Right
Description
r
Reads the object definition or table entry
m
Modifies the object definition or table entry
c
Creates a table entry or column
d
Destroys a table entry or column
You can combine operations on a single command line by separating each operation from the next with a comma (,).
Table 9-10 Class, Operator, and Rights Syntax--Examples
Operations
Syntax
Add read access rights to the owner class
o+r
Change owner. group, and world classes' access rights to modify only from whatever they were before
a=m
Add read and modify rights to the world and nobody classes
wn+m
Remove all four rights from the group, world, and nobody classes
gwn-rmcd
Add create and destroy rights to the owner class and add read and modify rights to the world and nobody classes
o+cd,wn+rm
Syntax for Owner and Group
principalname
For group
groupname.domainname
Syntax for Objects and Table Entries
Objects and table entries use different syntaxes.
For objects
objectname
For table entries
columnname=value],tablename
Note -
In this case, the brackets are part of the syntax.
Indexed names can specify more than one column-value pair. If so, the operation applies only to the entries that match all the column-value pairs. The more column-value pairs you provide, the more stringent the search.
For example:
Table 9-11 Object and Table Entry--Examples
Type
Example
Object
hosts.org_dir.sales.doc.com.
Table entry
`[uid=33555],passwd.org_dir.Eng.doc.com.'
Two-value table entry
`[name=sales,gid=2],group.org_dir.doc.com.'
Columns use a special version of indexed names. Because you can only work on columns with the nistbladm command, see "The nistbladm Command " for more information.
