The Update Manager policies specify custom Java classes that provide additional processing logic for each type of update transaction. By default, this additional processing is not defined in a standard master index application. You can define custom update policies using the Custom Plug-ins function in the master index project, which appears after the project is generated. The Custom Plug-in function also provides the ability to build and compile the custom Java code, and Sun Master Index automatically incorporates the classes when you generate the application. The Java classes defining the update policies are specified for the master index application in the UpdateManagerConfig element of the Best Record file.
There are seven types of update policies defined in the Update Manager.
Enterprise Merge Policy – The enterprise merge policy defines additional processing to perform when two enterprise objects are merged. This policy is defined by the EnterpriseMergePolicy element.
Enterprise Unmerge Policy – The enterprise unmerge policy defines additional processing to perform when an unmerge transaction occurs. This policy is defined by the EnterpriseUnmergePolicy element.
Enterprise Update Policy – The enterprise update policy defines additional processing to perform when a record is updated. This policy is defined by the EnterpriseUpdatePolicy element.
Enterprise Create Policy – The enterprise create policy defines additional processing to perform when a new record is inserted into the master index database. This policy is defined by the EnterpriseCreatePolicy element.
System Merge Policy – The system merge policy defines additional processing to perform when two system objects are merged. This policy is defined by the SystemMergePolicy element.
System Unmerge Policy – The system unmerge policy defines additional processing to perform when system objects are unmerged. This policy is defined by the SystemUnmergePolicy element.
UndoAssumeMatchPolicy – The undo assume match policy defines additional processing to perform when an assumed match transaction is reversed. This policy is defined by the UndoAssumeMatchPolicy element.
The update policy section includes a flag that can prevent the update policies from being carried out if no changes were made to the existing record. When set to “true”, the SkipUpdateIfNoChange flag prevents the update policies from being performed when no changes are made to an existing record. Setting the flag to true helps increase performance when processing a large number of updates.
