After the matching process is complete, you can load the data using either a SQL*Loader bulk loader or the Data Integrator Bulk Loader. Both are generated from the loader files created for the master index application. Like the Bulk Matcher, the Bulk Loader can be run on concurrent processors, each processing a different master data image file.
You can use the Data Integrator Bulk Loader to load data for an Oracle, MySQL, or SQL Server database. The SQL*Loader bulk loader can only be used for an Oracle database. With SQL*Loader, you need to drop the unique constraints and indexes using the SQL script provided before loading data, and then reinstate the constraints and indexes after loading the data.
