The bulk match process is configured by loader-config.xml, which is located in the conf subdirectory in the directory where you extracted the IBML Tool files. The process must be configured on each machine that is running a Bulk Matcher.
Perform the following steps on each machine processing bulk data.
Complete the steps under Creating the Cluster Synchronizer Database.
Navigate to the location where you extracted the IBML Tool.
Open conf/loader-config.xml.
Configure processing attributes by modifying the properties described in Initial Bulk Match and Load Tool Processing Configuration.
Configure the cluster synchronizer database connection properties by modifying the properties described in Cluster Synchronizer Database Configuration.
Configure the data reader and enter the name and location of the input file (see Data Reader Configuration for more information).
If the IBML Tool is running on multiple processors, modify the properties described in FTP Server Configuration.
If you are using SQL*Loader to load the master image into the master index database, modify the properties described in SQL*Loader Configuration.
When using the Bulk Matcher in match analysis mode, do any of the following:
To modify the match and duplicate thresholds for match analysis, enter new values for the duplicateThreshold and matchThreshold elements.
To modify the blocking query for match analysis, modify the query builder section (described in Initial Bulk Match and Load Tool Blocking Query Configuration).
To modify the match string for match analysis, modify the MatchingConfig section (described in Initial Bulk Match and Load Tool Match String Configuration).
Save and close the file.
Repeat the above steps for each load processor in the distributed environment.
To configure logging properties, continue to Configuring Initial Bulk Match and Load Tool Logging; otherwise, skip to Performing a Match Analysis.
