The Configuration Editor has built in validations to ensure that integrity is maintained between the configuration files. For example, it does not allow you to define a field for normalization if that field is not already defined in the object structure. While you can use the Configuration Editor to modify most of the configurable components, some components can only be modified using the XML editor. Following is a summary of which features can be configured using the Configuration Editor and which need to be modified using an XML editor.
You can modify most elements of the Object Definition file using the Configuration Editor. The following can only be modified using the XML editor:
Database type
Date format
Maximum field value
Minimum field value
It is not recommended you change the database type, but if you modify the database type or date format elements, you need to regenerate the application to create the updated database scripts. This does not recreate the Systems or Code Lists scripts; that needs to be done manually.
You can modify all elements in the Candidate Select file using the Configuration Editor. If you create a query to use in the EDM or to use for the matching query, you need to add the query to the appropriate file manually (the Threshold file or the Enterprise Data Manager file).
Most elements in the Threshold file cannot be modified using the Configuration Editor. You can only modify the duplicate and match thresholds from the Configuration Editor.
You can use the Configuration Editor to modify all commonly modified elements in the Match Field file, including defining standardization structures, normalization structures, and phonetic encoding. If you create custom classes to implement a block picker, pass controller, match engine, or standardization engine, you need to specify the implementation classes in this file using the XML editor.
The Configuration Editor does not modify the Best Record file. If you make any changes to the object structure (either through the Configuration Editor or XML editor) review this file to verify that all fields or objects are included in the survivor strategy and that the field and object names are correct.
The Configuration Editor does not modify the Best Record file. If you create a custom field validation class, you need to specify the implementation class in this file using the XML editor.
Most elements in the Enterprise Data Manager file are not modified using the Configuration Editor. You can add and delete fields that appear on the EDM and modify the display name and the value and input masks. All other field properties can only be modified using the XML editor.
Field integrity is maintained when you delete a field using the Configuration Editor. The field is automatically deleted from the EDM object structure and from any EDM page definitions that include the field, such as a search page or report.
You can modify all components of the Match Configuration file using the Configuration Editor, including adding and removing comparators. The Configuration Editor does not validate the extra parameters that can be used for certain comparators, so you should verify your changes by reviewing the match configuration file manually.
