The Create System Record page is where a user adds new records to the master index database. You can configure the name of the tabbed heading and the type of object returned. Do not modify the URL of the entrance to the Create System Record page. Following is a sample of the create-eo element.
<create-eo> <root-object>Person</root-object> <tab-name>Create System Record</tab-name> <tab-entrance>/stcedm/EnterEOCreateAction.do</tab-entrance> </create-eo> |
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click the Enterprise Data Manager file.
The file opens in the NetBeans XML editor.
Scroll to the page-definition element in the gui-definition element, and then to the create-eo element.
To specify a new object type for the objects you create, change the value of the root-object element.
For example:
<root-object>Customer</root-object> |
This must be the name of the parent object.
To specify a new name for the Create System Record tab, modify the value of the tab-name element.
<tab-name>Add Record</tab-name> |
Save and close the file.
