By default, the Matching Review page appears when a user logs on to the Enterprise Data Manager. You can specify any of the other tabbed pages as the initial view.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click the Enterprise Data Manager file.
The file opens in the NetBeans XML editor.
Scroll to the page-definition element in the gui-definition element, and then to the initial-screen element.
Do one of the following:
To display the Matching Review page first, change the value of the initial-screen element to “Matching Review”.
To display the Search page first, change the value of the initial-screen element to “EO Search”.
To display the Create System Record page first, change the value of the initial-screen element to “Create System Record”.
To display the History page first, change the value of the initial-screen element to “History”.
To display the Reports page first, change the value of the initial-screen element to “Reports”.
These values remain the same regardless of whether the tab name of the page has been changed. For example, if you change the name of the Matching Review page to “Potential Duplicate”, you would still specify “Matching Review” for that page to appear first.
Save and close the file.
