Configuring Sun Master Indexes (Repository)
Master Index Field Property Elements (Repository)
The following table lists and describes the properties you can define for each field inthe Object Definition file.
Element
Description
field-name
The name of the field. Follow the guidelines under Master Index Field Name Restrictions (Repository) when naming fields.
field-type
The data type of the field. Possible values are:
  • string - Fields of this type contain a string of characters.
  • date - Fields of this type contain a date value.
  • float - Fields of this type contain a floating point integer.
  • int - Fields of this type contain an integer.
  • char - Fields of this type contain a single character.
  • boolean - Fields of this type can contain either “true” or “false”.
size
The number of characters allowed in each field. If you modify this element, be sure to modify the length of the corresponding database column accordingly.
updateable
An indicator of whether the field can be updated from the EDM or by back-end messages. Specify true if the field can be updated, or specify false if it cannot.
required
An indicator of whether the field is required in order to save an enterprise object in the database. Specify true if the field is required, or specify false if it is not.
code-module
The identification code for the menu list that appears for this field in the EDM. This must match a value in the code column of the sbyn_comment_header database table. This element is optional.
maximum-value
The maximum value allowed in the field. To specify a value for a date field, use the format YYYY-MM-DD. This element is optional.
minimum-value
The minimum value allowed in the field. To specify a value for a date field, use the format YYYY-MM-DD. This element is optional.
pattern
The required pattern for the field. For more information about possible values and using Java patterns, see “Patterns” in the class list for java.util.regex in the Javadocs provided with J2SE Platform. You might want to define patterns for date, telephone, or SSN fields. Note that for the EDM, the pattern is further restricted by the value entered for the input mask. If no input mask is specified, all regex patterns are supported.
user-code
The processing code for the drop-down list that appears on the MIDM for the fields defined by the constraint–by property, described below. These codes are used for non-unique IDs, such as account numbers, insurance policies, credit cards, and so on.
Note –
This must match an entry in the code_list column of the sbyn_user_code database table.
constraint-by
The name of the field that contains the corresponding user–code value (described above) to use to validate the current field. The user–code and constraint-by properties are used in conjunction to define non-unique ID types, such as credit card numbers or account numbers. The first purpose is to define a drop-down list for the field that contains the user code value. The second purpose is to validate the field that contains the constraint value against definitions for the field with the user code value.
For example, if you store non-unique IDs such as credit card numbers or insurance policy numbers, you could create a field named ID Type with a user–code of CREDCARD (CREDCARD also needs to be defined as a code in the sbyn_user_code table). This gives the ID Type field a drop-down list based on the definitions for CREDCARD in the sbyn_user_code table. Definitions would be VISA, MASTERCARD, AMEX, and so on. You could then create a field named ID that would be constrained by the formats defined for the ID Type field. Any credit card numbers you enter would be validated against the format defined for the type of credit card you selected in ID Type.
key-type
An indicator of whether the field is used to identify unique objects. Specify true if the element is a unique object identifier; specify false if it is not. Key type fields should also be required fields unless a combination of fields are specified as key types for an object. This element is optional.
Note –
Each child object should contain at least one field that is a unique object identifier, but this is not required. If two or more fields are unique identifiers, the combined value of these fields must be unique in a given enterprise record.
