Key and value pairs are designed to fine-tune the operation of custom blocking queries. In the default blocking queries defined in the Candidate Select file, key and value pairs are not used. However, if you create a custom blocking query, you can configure the query to use key and value pairs. The key describes the option, and the value specifies the value of the option.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click the Threshold file.
Scroll to the execute-match element.
To specify a key and value pair, modify the values of the key and value attributes in the option element.
For example:
<option key="wildcard" value="true"/> |
Save and close the file.
