If a defined normalization structure is not needed, you can delete the normalization structure from the standardization configuration. If no data requires normalization, you can delete all normalization structures. It is not recommend that you delete a normalization definition once a system is in production. This can cause inconsistent match results.
In the Projects window, right-click the master index application you want to modify, and then click Open.
If the Configuration Editor dialog box appears, click Edit to check out the listed files.
The Configuration Editor appears.
In the Configuration Editor toolbar, click the Normalization tab.
The Normalization page appears.
In the Normalization Mappings list, click the definition you want to delete.
Click Remove.
On the Configuration Editor toolbar, click Save.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click the Match Field file.
The file opens in the NetBeans XML editor.
Scroll to the structures-to-normalize element in the StandardizationConfig element.
Do either of the following:
Save and close the file.
