Configuring Sun Master Indexes (Repository)
EDM Search Page Definition Elements
The following table lists and describes the elements you can configure in the Enterprise Data Manager file to define the search pages on the EDM.
Element
Description
screen-title
The name of the search as it appears in the Search Type drop-down list, from which users can select a type of search to perform.
field-per-row
The number of fields to display in each row on the search page.
show-euid
An indicator of whether to display the EUID. Specify true to display the EUID; otherwise specify false. Only display this field if you want it to take precedence over all other search criteria. When the EUID is displayed, it appears in its own labelled box.
show-lid
An indicator of whether to display the local ID and system fields. Specify true to display the fields; otherwise specify false. Only display these fields if you want them to take precedence over all other search criteria (except the EUID field). When the local ID is displayed, the local ID and system fields appear in their own labelled box.
instruction
A short statement to help the user process a search. The text you enter here appears above the search fields on the Search page.
