The OneExactMatch parameter determines how records above the match threshold are processed. This parameter can only be modified directly in the XML file. For more information, see Manager Service Configuration in Understanding Sun Master Index Configuration Options and Understanding Operational Processes, in Understanding Sun Master Index Processing .
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
Scroll to the OneExactMatch element in the DecisionMakerConfig element.
Change the value of the parameter-value element to true.
For example:
<parameter> <parameter-name>OneExactMatch</parameter-name> <parameter-type>java.lang.Boolean</parameter-type> <parameter-value>true</parameter-value> </parameter> |
Save and close the file.
Change value of the parameter-value element to false.
For example:
<parameter> <parameter-name>OneExactMatch</parameter-name> <parameter-type>java.lang.Boolean</parameter-type> <parameter-value>false</parameter-value> </parameter> |
