The default EUID generator creates sequential EUIDs based on the value specified for the EUID sequence in the sbyn_seq_table database table. If you create a new EUID generator class to process EUIDs differently, you must specify the name of the new class in the euid-generator-class element of master.xml.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
Scroll to the EuidGeneratorConfig element.
Change the value of the euid-generator-class element to the path and name of the new EUID generator class.
For example:
<euid-generator-class>com.sun.mdm.index.idgen.impl.MyEuidGenerator </euid-generator-class> |
Save and close the file.
