The merged-record-update element allows you to define whether updates can be made to records with a status of Merged.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
In the MasterControllerConfig element, change the value of the merged-record-update element to Enabled.
For example:
<merged-record-update>Enabled</merged-record-update> |
Save and close the file.
In the MasterControllerConfig element, change the value of the merged-record-update element to Disabled.
For example:
<merged-record-update>Disabled</merged-record-update> |
