Configuring Sun Master Indexes
Modifying the Master Index XML Files Directly
Make sure that when you modify the configuration files, you use the versioning controls in NetBeans to maintain version control. Even if you modify the files using the Master Index Configuration Editor, check the files in and out before and after using the editor.
There are a few restraints on modifying these files. In addition to the general rules listed below, the match or standardization engine you choose might place other requirements on customizations. Be sure to review Understanding the Master Index Match Engine and Understanding the Master Index Standardization Engine before modifying mefa.xml.
Keep the following guidelines in mind when modifying the XML files directly.
