Configuring Sun Master Indexes
Master Index Normalization and Standardization Structure Properties
The following table lists and describes the Configuration Editor fields and their corresponding XML elements that define the fields to be normalized or standardized in the master index application.
You can specify one or more variants for data to be standardized. A variant is a subset of a data type. For example, if the data type is address, variants are defined for addresses from different countries. The rule set for each country is called a variant. For a single variant, you only need to specify the variant if you need to standardize data that is not from the United States. If you are standardizing data from multiple countries, use the multiple domain selector. This requires that one field in the object structure identify which variant to use for each field that will be standardized. For example, the value of the Country field in a system record could be used to tell the standardization engine which variant to use for a particular set of data. If you specified the multiple domain selector in the domain-selector element, you must also define the identifying field and then map the values that can be populated into that field to their corresponding variant.
The following rules apply to the multiple domain selector:
For more information about the fields and elements described in the following table, see Understanding the Master Index Standardization Engine.
Configuration Editor Field
XML File Element or Attribute
Description
Data Type
standardization-type
The type of standardization to perform on the source fields. This is specific to the type of data being processed.
Domain Selector
domain-selector
The Java class used by the standardization engine to determine the variant of the data being processed. For the Master Index Standardization Engine, the following classes can be specified. If no selector is specified, the default is US. The Master Index Standardization Engine supports Australian, French, United Kingdom, and United States variants. Possible values for this field are:
  • com.sun.mdm.index.matching.impl. SingleDomainSelectorAU
  • com.sun.mdm.index.matching.impl. SingleDomainSelectorFR
  • com.sun.mdm.index.matching.impl. SingleDomainSelectorUK
  • com.sun.mdm.index.matching.impl. SingleDomainSelectorUS
  • com.sun.mdm.index.matching.impl. MultipleDomainSelector
Variant Field Name
locale-field-name
The ePath to an identifying field in the object structure that identifies which of the defined variants (element locale-codes) to use. If no field is specified for the Master Index Standardization Engine, the standardization engine defaults to the United States, regardless of whether any variants are defined. This field must be contained in the object that contains the fields defined for normalization in this structure.
Unnormalized Source
unnormalized-source- field-name
The field that contains the data to be normalized. The field is designated by its ePath (for example, Person.FirstName).
Unnormalized Standardization Component
standardized-object- field-id
An identification code that identifies the field to normalize to the standardization engine. This ID is specific to the standardization engine and must correspond to a standardization component defined by that engine.
Normalized Standardization Component
An identification code that identifies the field that contains the normalized data to the standardization engine. This is specific to the standardization engine in use and must correspond to a standardization component defined by that engine.
Normalized Target
standardized-target- field-name
The field that will store the normalized data. The field is designated by its ePath (for example, Person.Alias[*].StdLastName).
