Each type of phonetic encoder provided with Sun Master Index is defined in the PhoneticEncodersConfig section of mefa.xml. They are listed in the Encoders section of the Configuration Editor.
In the Projects window, right-click the Configuration node in the project you want to modify, and then click Edit.
The Configuration Editor appears.
Click the Phoneticized Fields tab.
The Phoneticized Field page appears.
In the Encoders section, click Add.
The Phonetic Encoder dialog box appears.
In the Encoder field, enter a descriptive name for the encoder.
In the Implementation Class field, enter the fully qualified Java path of the class to use for the encoder.
For more information about the encoder class paths, see Master Index Encoder Elements and Types.
Click OK.
The phonetic encoder is added to the Encoders list.
On the Configuration Editor toolbar, click Save.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click mefa.xml.
The file opens in the NetBeans XML editor.
Scroll to the PhoneticEncodersConfig section.
Create a new encoder element, and then define the elements described in Master Index Encoder Elements and Types.
Save and close the file.
