The survivor helper class determines how to retrieve values from system records and how to set them in the SBR. The default class is com.sun.mdm.index.survivor.impl.DefaultSurvivorHelper, which uses the ePath method to retrieve and set the values. You can create a custom survivor helper class to support other methods for retrieving and setting values. If you implement a custom survivor helper class, it must extendcom.sun.mdm.index.survivor.AbstractSurvivorHelper.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click update.xml.
The file opens in the NetBeans XML editor.
Scroll to the helper-class element in the SurvivorHelperConfig element.
Change the value of the helper-class element to the fully qualified name of new helper class.
For example:
<helper-class>com.sun.mdm.index.survivor.impl.MySurvivorHelper </helper-class> |
Save and close the file.
