Sun Java System Directory Server Enterprise Edition 6.0 Reference
Read Transformations
A read transformation is applied only during the response to a request. No transformation is applied during the request and the physical data is not changed.
The following diagram illustrates the principals of a read transformation.
Figure 23–4 Read Transformation
Figure shows a high level view of how a read transformation
A read transformation is defined on a data view, by using the dpconf command as follows:
$ dpconf add-virtual-transformation -h host -p port -D bindDN /
view-name read action attr-name parameters
Example 23–3 When Would You Use a Read Transformation
Imagine an organization has a legacy application whose function is to display person entries. The application does not support entries that do not contain a mail attribute. The physical data source has been upgraded and the email attribute no longer exists for person entries (e-mail addresses are constructed using other attributes).
The transformation required here is to add the mail attribute during the search response. This transformation changes the entry that is read from the database and adds a mail attribute whose value is No reverse transformation is required and the physical data is not changed.
Note that with the above transformation, the mail attribute makes no sense in a search request filter. Search request filters must contain physical attributes.
