Sun Java System Portal Server 7.1 Administration Guide
ProcedureTo Create a Site Definition
The robot finds resources and determines whether to add descriptions of those resources to the database. The determination of which servers to visit and what parts of those servers to index is called a site definition.
  1. Log in to the Portal Server management console.
  2. Select Search Servers from the menu bar, then select a search server.
  3. Select Robot from the menu bar, then Sites.
  4. Click New under Manage Sites and specify the configuration attributes for the site.
    For more information about the attributes, see Sites in Sun Java System Portal Server 7.1 Technical Reference.
  5. Click OK.
