Sun Cluster Geographic Edition System Administration Guide
Sun Cluster Geographic Edition System Administration Guide provides procedures for administering SunTM Cluster Geographic Edition software. This document is intended for experienced system administrators with extensive knowledge of Sun software and hardware. This document is not to be used as a planning or presales guide.
The instructions in this book assume knowledge of the SolarisTM Operating System (Solaris OS) and expertise with the volume manager software that is used with Sun Cluster software.
Related Documentation
Information about related Sun Cluster Geographic Edition topics is available in the documentation that is listed in the following table. All Sun Cluster Geographic Edition documentation is available at
Sun Cluster Geographic Edition Overview
Sun Java Enterprise System Glossary
Hardware administration
Individual hardware administration guides
Software installation
Sun Cluster Geographic Edition Installation Guide
System administration
Sun Cluster Geographic Edition Data Replication Guide for Sun StorEdge Availability Suite
Sun Cluster Geographic Edition Data Replication Guide for Hitachi TrueCopy
Sun Cluster Geographic Edition Data Replication Guide for EMC Symmetrix Remote Data Facility
Command and function references
Sun Cluster Geographic Edition Reference Manual
For a complete list of Sun Cluster documentation, see the release notes for your Sun Cluster software at
Using UNIX Commands
This document contains information about commands that are used to install, configure, or administer a Sun Cluster Geographic Edition configuration. This document might not contain complete information on basic UNIX® commands and procedures such as shutting down the system, booting the system, and configuring devices.
See one or more of the following sources for this information:
Documentation, Support, and Training
The Sun web site provides information about the following additional resources:
Obtaining Help
If you have problems installing or using Sun Cluster Geographic Edition software, contact your service provider and provide the following information:
Use the following commands to gather information about each node on your system for your service provider.
prtconf -v
Displays the size of the system memory and reports information about peripheral devices
psrinfo -v
Displays information about processors
showrev –p
Reports which patches are installed
prtdiag -v
Displays system diagnostic information
geoadm -V
Displays the Sun Cluster Geographic Edition software release information
Provides a snapshot of the cluster status
scconf –p
Lists cluster configuration information
geoadm status
Displays the Sun Cluster Geographic Edition runtime status of the local cluster
Also have available the contents of the /var/adm/messages file.
Typographic Conventions
The following table describes the typographic conventions that are used in this book.
Table P–1 Typographic Conventions
The names of commands, files, and directories, and onscreen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
What you type, contrasted with onscreen computer output
machine_name% su
Placeholder: replace with a real name or value
The command to remove a file is rm filename.
Book titles, new terms, and terms to be emphasized
Read Chapter 6 in the User's Guide.
A cache is a copy that is stored locally.
Do not save the file.
Note: Some emphasized items appear bold online.
Shell Prompts in Command Examples
The following table shows the default UNIX system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts
C shell
C shell for superuser
Bourne shell and Korn shell
Bourne shell and Korn shell for superuser
