SunSHIELD Basic Security Module Guide
acl token
The acl token records information about ACLs. It consists of four fixed fields. The fixed fields are: a token ID that identifies this token as an acl token, a field that specifies the ACL type, an ACL ID field, and a field that lists the permissions associated with this ACL. The acl token appears as follows:
Figure A-2 acl Token Format
Graphic
