SunSHIELD Basic Security Module Guide
Kernel-Level Generated Audit Records
These audit records are created by system calls that are used by the kernel. The records are sorted alphabetically by system call. The description of each record includes:
Table A-5 accept(2)
Event Name
Event ID
Event Class
Mask
AUE_ACCEPT
33
nt
0x00000100
Format (if the socket address is not part of the AF_INET family):
header-token
arg-token                 (1, "fd", file descriptor)
text-token                 ("bad socket address")
text-token                 ("bad peer address")
subject-token
return-token
Format (if the socket address is part of the AF_INET family):
header-token
If there is no vnode for this file descriptor:
  [arg-token]               (1, "Bad fd", file descriptor)
or if the socket is not bound:
  [arg-token                (1, "fd", file descriptor)
text-token]               ("socket not bound")
or if the socket address length = 0:
text-token]               ("bad socket address")
For all other conditions:
  [socket-inet-token]       ("socket address")
socket-inet-token         ("socket address")
subject-token
return-token
Table A-6 access(2)
Event Name
Event ID
Event Class
Mask
AUE_ACCESS
14
fa
0x00000004
Format:
	header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-7 acl(2) - SETACL command
Event Name
Event ID
Event Class
Mask
AUE_ACLSET
251
fm
0x00000008
Format:
header-token
arg-token                (2, "cmd", SETACL)
arg-token                (3, "nentries", number of ACL entries)
  (0..n)[acl-token]        (ACLs)
subject-token
return-token
Table A-8 acct(2)
Event Name
Event ID
Event Class
Mask
AUE_ACCT
18
ad
0x00000800
Format (zero path):
	header-token
	argument-token      (1, "accounting off", 0)
	subject-token
	return-token
Format (non-zero path):
	header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-9 adjtime(2)
Event Name
Event ID
Event Class
Mask
AUE_ADJTIME
50
ad
0x00000800
Format:
	header-token
	subject-token
	return-token
Table A-10 audit(2)
Event Name
Event ID
Event Class
Mask
AUE_AUDIT
211
no
0x00000000
Format:
	header-token
	subject-token
	return-token
Table A-11 auditon(2) - get car
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_GETCAR
224
ad
0x00000800
Format:
	header-token
	subject-token
	return-token
Table A-12 auditon(2) - get event class
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_GETCLASS
231
ad
0x00000800
Format:
	header-token
	subject-token
	return-token
Table A-13 auditon(2) - get audit state
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_GETCOND
229
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-14 auditon(2) - get cwd
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_GETCWD
223
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-15 auditon(2) - get kernal mask
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_GETKMASK
221
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-16 auditon(2) - get audit statistics
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_GETSTAT
225
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-17 auditon(2) - GPOLICY command
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_GPOLICY
114
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-18 auditon(2) - GQCTRL command
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_GQCTRL
145
ad
0x00000800
Format:
	header-token
	subject-token
	return-token
Table A-19 auditon(2) - set event class
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_SETCLASS
232
ad
0x00000800
Format:
	header-token
	[argument-token]      (2, "setclass:ec_event", event number)
	[argument-token]      (3, "setclass:ec_class", class mask)
subject-token
return-token
Table A-20 auditon(2) - set audit state
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_SETCOND
230
ad
0x00000800
Format:
header-token
	[argument-token]      (3, "setcond", audit state)
subject-token
	return-token
Table A-21 auditon(2) - set kernal mask
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_SETKMASK
222
ad
0x00000800
Format:
header-token
	[argument-token]      (2, "setkmask:as_success", kernel mask)
	[argument-token]      (2, "setkmask:as_failure", kernel mask)
return-token
Table A-22 auditon(2) - set mask per session ID
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_SETSMASK
228
ad
0x00000800
Format:
header-token
	[argument-token]      (3, "setsmask:as_success", session ID mask)
	[argument-token]      (3, "setsmask:as_failure", session ID mask)
subject-token
return-token
Table A-23 auditon(2) - reset audit statistics
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_SETSTAT
226
ad
0x00000800
Format:
header-token
	subject-token
	return-token
Table A-24 auditon(2) - set mask per uid
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_SETUMASK
227
ad
0x00000800
Format:
header-token
	[argument-token]      (3, "setumask:as_success", audit ID mask)
	[argument-token]      (3, "setumask:as_failure", audit ID mask)
subject-token
	return-token
Table A-25 auditon(2) - SPOLICY command
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_SPOLICY
147
ad
0x00000800
Format:
header-token
	[argument-token]      (1, "policy", audit policy flags)
subject-token
	return-token
Table A-26 auditon(2) - SQCTRL command
Event Name
Event ID
Event Class
Mask
AUE_AUDITON_SQCTRL
146
ad
0x00000800
Format:
header-token
	[argument-token]      (3,"setqctrl:aq_hiwater", queue control param.)
	[argument-token]      (3,"setqctrl:aq_lowater", queue control param.)
	[argument-token]      (3,"setqctrl:aq_bufsz", queue control param.)
	[argument-token]      (3,"setqctrl:aq_delay", queue control param.)
subject-token
	return-token
Table A-27 auditsvc(2)
Event Name
Event ID
Event Class
Mask
AUE_AUDITSVC
136
ad
0x00000800
Format (valid file descriptor):
header-token
	[path-token]
	[attr-token]
subject-token
	return-token
Format (not valid file descriptor):
header-token
argument-token      (1, "no path: fd", fd)
subject-token
	return-token
Table A-28 bind(2)
Event Name
Event ID
Event Class
Mask
AUE_BIND
34
nt
0x00000100
Format:
header-token
or if the socket is not of the AF_INET family:
for all other conditions:
subject-token
return-token
Table A-29 chdir(2)
Event Name
Event ID
Event Class
Mask
AUE_CHDIR
8
pc
0x00000080
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-30 chmod(2)
Event Name
Event ID
Event Class
Mask
AUE_CHMOD
10
fm
0x00000008
Format:
header-token
argument-token      (2, "new file mode", mode)
path-token
	[attr-token]
	subject-token
	return-token
Table A-31 chown(2)
Event Name
Event ID
Event Class
Mask
AUE_CHOWN
11
fm
0x00000008
Format:
header-token
argument-token      (2, "new file uid", uid)
argument-token      (3, "new file gid", gid)
path-token
	[attr-token]
	subject-token
	return-token
Table A-32 chroot(2)
Event Name
Event ID
Event Class
Mask
AUE_CHROOT
24
pc
0x00000080
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-33 close(2)
Event Name
Event ID
Event Class
Mask
AUE_CLOSE
112
cl
0x00000040
Format:
	<file system object>
header-token
argument-token      (1, "fd", file descriptor)
	[path-token]
	[attr-token]
	subject-token
	return-token
Table A-34 connect(2)
Event Name
Event ID
Event Class
Mask
AUE_CONNECT
32
nt
0x00000100
header-token
subject-token
return-token
header-token
subject-token
return-token
Table A-35 creat(2)
Event Name
Event ID
Event Class
Mask
AUE_CREAT
4
fc
0x00000010
Format
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-36 doorfs(2) - DOOR_BIND
Event Name
Event ID
Event Class
Mask
AUE_DOORFS_DOOR_BIND
260
ip
0x00000200
Format:
header-token
arg-token           (1, "door ID", door ID)
subject-token
return-token
Table A-37 doorfs(2) - DOOR_CALL
Event Name
Event ID
Event Class
Mask
AUE_DOORFS_DOOR_CALL
254
ip
0x00000200
Format:
header-token
process-token      (for process that owns the door)
subject-token
return-token
Table A-38 doorfs(2) - DOOR_CREATE
Event Name
Event ID
Event Class
Mask
AUE_DOORFS_DOOR_CREATE
256
ip
0x00000200
Format:
header-token
arg-token           (1, "door attr", door attributes)
subject-token
return-token
Table A-39 doorfs(2) - DOOR_CRED
Event Name
Event ID
Event Class
Mask
AUE_DOORFS_DOOR_CRED
259
ip
0x00000200
Format:
header-token
subject-token
return-token
Table A-40 doorfs(2) - DOOR_INFO
Event Name
Event ID
Event Class
Mask
AUE_DOORFS_DOOR_INFO
258
ip
0x00000200
Format:
header-token
subject-token
return-token
Table A-41 doorfs(2) - DOOR_RETURN
Event Name
Event ID
Event Class
Mask
AUE_DOORFS_DOOR_RETURN
255
ip
0x00000200
Format:
header-token
subject-token
return-token
Table A-42 doorfs(2) - DOOR_REVOKE
Event Name
Event ID
Event Class
Mask
AUE_DOORFS_DOOR_REVOKE
257
ip
0x00000200
Format:
header-token
subject-token
return-token
Table A-43 doorfs(2) - DOOR_UNBIND
Event Name
Event ID
Event Class
Mask
AUE_DOORFS_DOOR_UNBIND
261
ip
0x00000200
Format:
header-token
subject-token
return-token
Table A-44 enter prom
Event Name
Event ID
Event Class
Mask
AUE_ENTERPROM
153
na
0x00000400
Format:
header-token
text-token      (addr, "monitor PROM"|"kadb")
subject-token
	return-token
Table A-45 exec(2)
Event Name
Event ID
Event Class
Mask
AUE_EXEC
7
pc,ex
0x40000080
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-46 execve(2)
Event Name
Event ID
Event Class
Mask
AUE_EXECVE
23
pc,ex
0x40000080
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-47 exit prom
Event Name
Event ID
Event Class
Mask
AUE_EXITPROM
154
na
0x00000400
Format:
header-token
subject-token
	return-token
Table A-48 exit(2)
Event Name
Event ID
Event Class
Mask
AUE_EXIT
1
pc
0x00000080
Format:
header-token
	subject-token
	return-token
Table A-49 facl(2) - SETACL command
Event Name
Event ID
Event Class
Mask
AUE_FACLSET
252
fm
0x00000008
Format (zero path):
header-token
arg-token              (1, "no path: fd", file descriptor)
subject-token
return-token
header-token
path-token
  [attr-token]
subject-token
return-token
Table A-50 fchdir(2)
Event Name
Event ID
Event Class
Mask
AUE_FCHDIR
68
pc
0x00000080
Format:
header-token
	[path-token]
	[attr-token]
	subject-token
	return-token
Table A-51 fchmod(2)
Event Name
Event ID
Event Class
Mask
AUE_FCHMOD
39
fm
0x00000008
header-token
	[path-token]
	[attr-token]
	subject-token
	return-token
header-token
subject-token
	return-token
Table A-52 fchown(2)
Event Name
Event ID
Event Class
Mask
AUE_FCHOWN
38
fm
0x00000008
header-token          (2, "new file uid", uid)
	[path-token]
	[attr-token]
	subject-token
	return-token
Format (non-file descriptor):
header-token
subject-token
	return-token
Table A-53 fchroot(2)
Event Name
Event ID
Event Class
Mask
AUE_FCHROOT
69
pc
0x00000080
Format:
header-token
	[path-token]
	[attr-token]
	subject-token
	return-token
Table A-54 fcntl(2)
Event Name
Event ID
Event Class
Mask
AUE_FCNTL (cmd=F_GETLK, F_SETLK, F_SETLKW)
30
fm
0x00000008
Format (file descriptor):
header-token
argument-token      (2, "cmd", cmd)
path-token
	attr-token
	subject-token
	return-token
Format (bad file descriptor):
header-token
subject-token
	return-token
Table A-55 fork(2)
Event Name
Event ID
Event Class
Mask
AUE_FORK
2
pc
0x00000080
Format:
header-token
	[argument-token]      (0, "child PID", pid)
subject-token
	return-token
The fork() return values are undefined because the audit record
is produced at the point that the child process is spawned.
Table A-56 fork1(2)
Event Name
Event ID
Event Class
Mask
AUE_FORK1
241
pc
0x00000080
Format:
header-token
subject-token
	return-token
The fork1() return values are undefined because the audit record
Table A-57 fstatfs(2)
Event Name
Event ID
Event Class
Mask
AUE_FSTATFS
55
fa
0x00000004
header-token
	[path-token]
	[attr-token]
	subject-token
	return-token
header-token
subject-token
	return-token
Table A-58 getaudit(2)
Event Name
Event ID
Event Class
Mask
AUE_GETAUDIT
132
ad
0x00000800
Format:
header-token
	subject-token
	return-token
Table A-59 getauid(2)
Event Name
Event ID
Event Class
Mask
AUE_GETAUID
130
ad
0x00000800
Format:
header-token
	subject-token
	return-token
Table A-60 getmsg(2)
Event Name
Event ID
Event Class
Mask
AUE_GETMSG
217
nt
0x00000100
Format:
header-token
argument-token      (4, "pri", priority)
subject-token
	return-token
Table A-61 getmsg - accept
Event Name
Event ID
Event Class
Mask
AUE_SOCKACCEPT
247
nt
0x00000100
Format:
header-token
socket-inet-token
subject-token
	return-token
Table A-62 getmsg - receive
Event Name
Event ID
Event Class
Mask
AUE_SOCKRECEIVE
250
nt
0x00000100
Format:
header-token
	socket-inet-token
subject-token
	return-token
Table A-63 getpmsg(2)
Event Name
Event ID
Event Class
Mask
AUE_GETPMSG
219
nt
0x00000100
Format:
header-token
subject-token
return-token
Table A-64 getportaudit(2)
Event Name
Event ID
Event Class
Mask
AUE_GETPORTAUDIT
149
ad
0x00000800
Format:
header-token
subject-token
return-token
Table A-65 inst_sync(2)
Event Name
Event ID
Event Class
Mask
AUE_INST_SYNC
264
ad
0x00000800
Format:
header-token
arg-token           (2, "flags", flags value)
subject-token
return-token
Table A-66 ioctl(2)
Event Name
Event ID
Event Class
Mask
AUE_IOCTL
158
io
0x20000000
Format (good file descriptor):
header-token
path-token
	[attr-token]
argument-token      (2, "cmd" ioctl cmd)
argument-token      (3, "arg" ioctl arg)
subject-token
	return-token
Format (socket):
header-token
	[socket-token]
subject-token
	return-token
Format (non-file file descriptor):
header-token
argument-token      (2, "cmd", ioctl cmd)
argument-token      (3, "arg", ioctl arg)
subject-token
	return-token
Format (bad file name):
header-token
subject-token
	return-token
Table A-67 kill(2)
Event Name
Event ID
Event Class
Mask
AUE_KILL
15
pc
0x00000080
Format (valid process):
header-token
	argument-token      (2, "signal", signo)
	[process-token]
subject-token
	return-token
Format (zero or negative process):
header-token
argument-token      (1, "process", pid))
subject-token
	return-token
Table A-68 lchown(2)
Event Name
Event ID
Event Class
Mask
AUE_LCHOWN
237
fm
0x00000008
Format:
header-token
path-token
	[attr-token]
subject-token
return-token
Table A-69 link(2)
Event Name
Event ID
Event Class
Mask
AUE_LINK
5
fc
0x00000010
Format:
header-token
	path-token      (from path)
	[attr-token]     (from path)
path-token      (to path)
	subject-token
	return-token
Table A-70 lstat(2)
Event Name
Event ID
Event Class
Mask
AUE_LSTAT
17
fa
0x00000004
Format:
header-token
	path-token
	[attr-token]
subject-token
	return-token
Table A-71 lxstat(2)
Event Name
Event ID
Event Class
Mask
AUE_LXSTAT
236
fa
0x00000004
Format:
header-token
	path-token
	[attr-token]
subject-token
	return-token
Table A-72 memcntl(2)
Event Name
Event ID
Event Class
Mask
AUE_MEMCNTL
238
ot
0x80000000
Format:
header-token
	argument-token      (1, "base", base address)
argument-token      (2, "len", length)
argument-token      (3, "cmd", command)
argument-token      (4, "arg", command args)
argument-token      (5, "attr", command attributes)
argument-token      (6, "mask", 0)
subject-token
	return-token
Table A-73 mkdir(2)
Event Name
Event ID
Event Class
Mask
AUE_MKDIR
47
fc
0x00000010
Format:
header-token
	argument-token      (2, "mode", mode)
path-token
	[attr-token]
subject-token
	return-token
Table A-74 mknod(2)
Event Name
Event ID
Event Class
Mask
AUE_MKNOD
9
fc
0x00000010
Format:
header-token
argument-token      (3, "dev", dev)
path-token
	[attr-token]
subject-token
	return-token
Table A-75 mmap(2)
Event Name
Event ID
Event Class
Mask
AUE_MMAP
210
no
0x00000000
header-token
argument-token      (1, "addr", segment address)
argument-token      (2, "len", segment length)
	[path-token]
	[attr-token]
subject-token
	return-token
header-token
subject-token
	return-token
Table A-76 modctl(2) - bind module
Event Name
Event ID
Event Class
Mask
AUE_MODADDMAJ
246
ad
0x00000800
Format:
	header-token
	[text-token]      driver major number)
	[text-token]      (driver name)
text-token        (root dir.|"no rootdir")
text-token        (driver major number|"no drvname")
argument-token        (5, "", number of aliases)
	(0..n)[text-token]      (aliases)
subject-token
	return-token
Table A-77 modctl(2) - configure module
Event Name
Event ID
Event Class
Mask
AUE_MODCONFIG
245
ad
0x00000800
Format:
header-token
subject-token
	return-token
Table A-78 modctl(2) - load module
Event Name
Event ID
Event Class
Mask
AUE_MODLOAD
243
ad
0x00000800
Format:
header-token
	[text-token]      (default path)
text-token        (filename path)
subject-token
	return-token
Table A-79 modctl(2) - unload module
Event Name
Event ID
Event Class
Mask
AUE_MODUNLOAD
244
ad
0x00000800
Format:
header-token
	argument-token      (1, "id", module ID)
subject-token
	return-token
Table A-80 mount(2)
Event Name
Event ID
Event Class
Mask
AUE_MOUNT
62
ad
0x00000800
Format (UNIX file system):
header-token
argument-token      (3, "flags", flags)
text-token             (filesystem type)
path-token
	[attr-token]
	subject-token
	return-token
Format (NFS file system):
header-token
text-token             (host name)
argument-token      (3, "internal flags", flags)
Table A-81 msgctl(2) - IPC_RMID command
Event Name
Event ID
Event Class
Mask
AUE_MSGCTL_RMID
85
ip
0x00000200
Format:
header-token
argument-token      (1, "msg ID", message ID)
	[ipc-token]
	subject-token
	return-token
The ipc and ipc_perm tokens are not included if the msg ID is
not valid.
Table A-82 msgctl(2) - IPC_SET command
Event Name
Event ID
Event Class
Mask
AUE_MSGCTL_SET
86
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
not valid.
Table A-83 msgctl(2) - IPC_STAT command
Event Name
Event ID
Event Class
Mask
AUE_MSGCTL_STAT
87
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
not valid.
Table A-84 msgget(2)
Event Name
Event ID
Event Class
Mask
AUE_MSGGET
88
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
not valid.
Table A-85 msgrcv(2)
Event Name
Event ID
Event Class
Mask
AUE_MSGRCV
89
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
not valid.
Table A-86 msgsnd(2)
Event Name
Event ID
Event Class
Mask
AUE_MSGSND
90
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
not valid.
Table A-87 munmap(2)
Event Name
Event ID
Event Class
Mask
AUE_MUNMAP
214
cl
0x00000040
Format:
header-token
argument-token      (1, "addr", address of memory)
argument-token      (2, "len", memory segment size)
subject-token
	return-token
Table A-88 old nice(2)
Event Name
Event ID
Event Class
Mask
AUE_NICE
203
pc
0x00000080
Format:
header-token
	subject-token
	return-token
Table A-89 open(2) - read
Event Name
Event ID
Event Class
Mask
AUE_OPEN_R
72
fr
0x00000001
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-90 open(2) - read,creat
Event Name
Event ID
Event Class
Mask
AUE_OPEN_RC
73
fc,fr
0x00000011
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-91 open(2) - read,creat,trunc
Event Name
Event ID
Event Class
Mask
AUE_OPEN_RTC
75
fc,fd,fr
0x00000031
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-92 open(2) - read,trunc
Event Name
Event ID
Event Class
Mask
AUE_OPEN_RT
74
fd,fr
0x00000021
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-93 open(2) - read,write
Event Name
Event ID
Event Class
Mask
AUE_OPEN_RW
80
fr,fw
0x00000003
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-94 open(2) - read,write,creat
Event Name
Event ID
Event Class
Mask
AUE_OPEN_RWC
81
fr,fw,fc
0x00000013
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-95 open(2) - read,write,create,trunc
Event Name
Event ID
Event Class
Mask
AUE_OPEN_RWTC
83
fr,fw,fc,fd
0x00000033
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-96 open(2) - read,write,trunc
Event Name
Event ID
Event Class
Mask
AUE_OPEN_RWT
82
fr,fw,fd
0x00000023
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-97 open(2) - write
Event Name
Event ID
Event Class
Mask
AUE_OPEN_W
76
fw
0x00000002
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-98 open(2) - write,creat
Event Name
Event ID
Event Class
Mask
AUE_OPEN_WC
77
fw,fc
0x00000012
Format:
	header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-99 open(2) - write,creat,trunc
Event Name
Event ID
Event Class
Mask
AUE_OPEN_WTC
79
fw,fc,fd
0x00000032
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-100 open(2) - write,trunc
Event Name
Event ID
Event Class
Mask
AUE_OPEN_WT
78
fw,fd
0x00000022
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-101 p_online(2)
Event Name
Event ID
Event Class
Mask
AUE_P_ONLINE
262
ad
0x00000800
header-token
arg-token           (1, "processor ID", processor ID)
text-token           (text form of flags value: P_ONLINE, P_OFFLINE, P_STATUS)
subject-token
return-token
Table A-102 pathconf(2)
Event Name
Event ID
Event Class
Mask
AUE_PATHCONF
71
fa
0x00000004
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-103 pipe(2)
Event Name
Event ID
Event Class
Mask
AUE_PIPE
185
no
0x00000000
Format:
header-token
	subject-token
	return-token
Table A-104 priocntlsys(2)
Event Name
Event ID
Event Class
Mask
AUE_PRIOCNTLSYS
212
pc
0x0000080
Format:
header-token
argument-token      (1, "pc_version", priocntl version num.)
argument-token      (3,"cmd", command)
subject-token
	return-token
Table A-105 process dumped core
Event Name
Event ID
Event Class
Mask
AUE_CORE
111
fc
0x0000010
Format:
header-token
	path-token
	[attr-token]
argument-token      (1, "signal", signal)
subject-token
	return-token
Table A-106 processor_bind(2)
Event Name
Event ID
Event Class
Mask
AUE_PROCESSOR_BIND
263
ad
0x00000800
Format (no processor bound):
header-token
arg-token             (1, "ID type", type of ID)
arg-token             (2, "ID", ID value)
text-token             ("PBIND_NONE")
process-token        (for process whose threads are bound to the processor)
subject-token
return-token
Format (with processor bound):
header-token
arg-token             (3, "processor ID", processor ID)
subject-token
return-token
Table A-107 putmsg(2)
Event Name
Event ID
Event Class
Mask
AUE_PUTMSG
216
nt
0x00000100
Format:
header-token
subject-token
	return-token
Table A-108 putmsg-connect
Event Name
Event ID
Event Class
Mask
AUE_SOCKCONNECT
248
nt
0x00000100
Format:
header-token
	socket-inet-token
subject-token
	return-token
Table A-109 putmsg-send
Event Name
Event ID
EventClass
Mask
AUE_SOCKSEND
249
nt
0x00000100
Format:
header-token
socket-inet-token
subject-token
	return-token
Table A-110 putpmsg(2)
Event Name
Event ID
Event Class
Mask
AUE_PUTPMSG
218
nt
0x00000100
Format:
header-token
subject-token
	return-token
Table A-111 readlink(2)
Event Name
Event ID
Event Class
Mask
AUE_READLINK
22
fr
0x00000001
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-112 rename(2)
Event Name
Event ID
Event Class
Mask
AUE_RENAME
42
fc,fd
0x00000030
Format:
header-token
path-token       (from name)
	[attr-token]      (from name)
	[path-token]     (to name)
subject-token
return-token
Table A-113 rmdir(2)
Event Name
Event ID
Event Class
Mask
AUE_RMDIR
48
fd
0x00000020
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-114 semctl(2) - getall
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_GETALL
105
ip
0x00000200
Format:
header-token
argument-token      (1, "sem ID", semaphore ID)
	[ipc-token]
	subject-token
	return-token
The ipc and ipc_perm tokens are not included if the semaphore ID
is not valid.
Table A-115 semctl(2) - GETNCNT command
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_GETNCNT
102
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
is not valid.
Table A-116 semctl(2) - GETPID command
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_GETPID
103
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
ID is not valid.
Table A-117 semctl(2) - GETVAL command
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_GETVAL
104
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
is not valid.
Table A-118 semctl(2) - GETZCNT command
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_GETZCNT
106
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
ID is not valid.
Table A-119 semctl(2) - IPC_RMID command
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_RMID
99
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
is not valid.
Table A-120 semctl(2) - IPC_SET command
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_SET
100
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
ID is not valid.
Table A-121 semctl(2) - SETALL command
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_SETALL
108
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
is not valid.
Table A-122 semctl(2) - SETVAL command
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_SETVAL
107
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
ID is not valid.
Table A-123 semctl(2) - IPC_STAT command
Event Name
Event ID
Event Class
Mask
AUE_SEMCTL_STAT
101
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
Table A-124 semget(2)
Event Name
Event ID
Event Class
Mask
AUE_SEMGET
109
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
The ipc and ipc_perm tokens are not included if the system call
failed.
Table A-125 semop(2)
Event Name
Event ID
Event Class
Mask
AUE_SEMOP
110
ip
0x00000200
Format:
header-token
	[ipc-token]
subject-token
	return-token
is not valid.
Table A-126 setaudit(2)
Event Name
Event ID
Event Class
Mask
AUE_SETAUDIT
133
ad
0x00000800
Format (valid program stack address):
header-token
argument-token      (1, "setaudit:auid", audit user ID)
argument-token      (1, "setaudit:port", terminal ID)
argument-token      (1, "setaudit:machine", terminal ID)
argument-token      (1, "setaudit:as_success", preselection mask)
argument-token      (1, "setaudit:as_failure", preselection mask)
argument-token      (1, "setaudit:asid", audit session ID)
subject-token
	return-token
Format (not valid program stack address):
header-token
	subject-token
	return-token
Table A-127 setauid(2)
Event Name
Event ID
Event Class
Mask
AUE_SETAUID
131
ad
0x00000800
Format:
header-token
argument-token      (2, "setauid", audit user ID)
subject-token
	return-token
Table A-128 setegid(2)
Event Name
Event ID
Event Class
Mask
AUE_SETEGID
214
pc
0x00000080
Format:
header-token
argument-token      (1, "gid", group ID)
subject-token
	return-token
Table A-129 seteuid(2)
Event Name
Event ID
Event Class
Mask
AUE_SETEUID
215
pc
0x00000080
Format:
header-token
argument-token      (1, "gid", user ID)
subject-token
	return-token
Table A-130 old setgid(2)
Event Name
Event ID
Event Class
Mask
AUE_SETGID
205
pc
0x00000080
Format:
header-token
subject-token
	return-token
Table A-131 setgroups(2)
Event Name
Event ID
Event Class
Mask
AUE_SETGROUPS
26
pc
0x00000080
Format:
header-token
	[argument-token]      (1, "setgroups", group ID)
subject-token
	return-token
One argument-token for each group set.
Table A-132 setpgrp(2)
Event Name
Event ID
Event Class
Mask
AUE_SETPGRP
27
pc
0x00000080
Format:
header-token
	subject-token
	return-token
Table A-133 setregid(2)
Event Name
Event ID
Event Class
Mask
AUE_SETREGID
41
pc
0x00000080
Format:
header-token
arg-token           (1, "rgid", real group ID)
arg-token           (2, "egid", effective group ID)
subject-token
return-token
Table A-134 setreuid(2)
Event Name
Event ID
Event Class
Mask
AUE_SETREUID
40
pc
0x00000080
Format:
header-token
arg-token           (1, "ruid", real user ID)
arg-token           (2, "euid", effective user ID)
subject-token
return-token
Table A-135 setrlimit(2)
Event Name
Event ID
Event Class
Mask
AUE_SETRLIMIT
51
ad
0x00000800
Format:
header-token
	subject-token
	return-token
Table A-136 old setuid(2)
Event Name
Event ID
Event Class
Mask
AUE_OSETUID
200
pc
0x00000080
Format:
header-token
argument-token      (1, "uid", user ID)
subject-token
	return-token
Because of a current bug in the audit software, this token is
reported as AUE_OSETUID.
Table A-137 shmat(2)
Event Name
Event ID
Event Class
Mask
AUE_SHMAT
96
ip
0x00000200
Format:
header-token
argument-token      (1, "shmid", shared memory ID)
argument-token      (2, "shmaddr", shared mem addr)
	[ipc-token]
	[ipc_perm-token]
	subject-token
	return-token
The ipc and ipc_perm tokens are not included if the shared memory
segment ID is not valid.
Table A-138 shmctl(2) - IPC_RMID command
Event Name
Event ID
Event Class
Mask
AUE_SHMCTL_RMID
92
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
memory segment ID is not valid.
Table A-139 shmctl(2) - IPC_SET command
Event Name
Event ID
Event Class
Mask
AUE_SHMCTL_SET
93
ip
0x00000200
Format:
header-token
	[ipc-token]
	[ipc_perm-token]
	subject-token
	return-token
Table A-140 shmctl(2) - IPC_STAT command
Event Name
Event ID
Event Class
Mask
AUE_SHMCTL_STAT
94
ip
0x00000200
Format:
header-token
	[ipc-token]
	subject-token
	return-token
Table A-141 shmdt(2)
Event Name
Event ID
Event Class
Mask
AUE_SHMDT
97
ip
0x00000200
Format:
header-token
argument-token      (1, "shmaddr", shared mem addr)
subject-token
	return-token
Table A-142 shmget(2)
Event Name
Event ID
Event Class
Mask
AUE_SHMGET
95
ip
0x00000200
Format:
header-token
arg-token           (0, "shmid", shared memory ID)
 [ipc_perm-token]
 [ipc-token]
subject-token
return-token
The ipc and ipc_perm tokens are not included for failed events.
Table A-143 shutdown(2)
Event Name
Event ID
Event Class
Mask
AUE_SHUTDOWN
46
nt
0x00000100
header-token
text-token]             ("bad peer address")
subject-token
return-token
header-token
subject-token
return-token
Table A-144 stat(2)
Event Name
Event ID
Event Class
Mask
AUE_STAT
16
fa
0x00000004
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-145 statfs(2)
Event Name
Event ID
EventClass
Mask
AUE_STATFS
54
fa
0x00000004
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-146 statvfs(2)
Event Name
Event ID
Event Class
Mask
AUE_STATVFS
234
fa
0x00000004
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-147 stime(2)
Event Name
Event ID
Event Class
Mask
AUE_STIME
201
ad
0x00000800
Format:
header-token
	subject-token
	return-token
Table A-148 symlink(2)
Event Name
Event ID
Event Class
Mask
AUE_SYMLINK
21
fc
0x00000010
Format:
header-token
text-token      (symbolic link string)
path-token
	[attr-token]
	subject-token
	return-token
Table A-149 sysinfo(2)
Event Name
Event ID
Event Class
Mask
AUE_SYSINFO
39
ad
0x00000800
Format:
header-token
argument-token      (1, "cmd", command)
text-token             (name)
subject-token
	return-token
Table A-150 system booted
Event Name
Event ID
Event Class
Mask
AUE_SYSTEMBOOT
113
na
0x00000400
Format:
header-token
text-token      ("booting kernel")
return-token
Table A-151 umount(2) - old version
Event Name
Event ID
Event Class
Mask
AUE_UMOUNT
12
ad
0x00000800
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-152 unlink(2)
Event Name
Event ID
Event Class
Mask
AUE_UNLINK
6
fd
0x00000020
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-153 old utime(2)
Event Name
Event ID
Event Class
Mask
AUE_UTIME
202
fm
0x00000008
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-154 utimes(2)
Event Name
Event ID
Event Class
Mask
AUE_UTIMES
49
fm
0x00000008
Format:
header-token
path-token
	[attr-token]
subject-token
	return-token
Table A-155 utssys(2) - fusers
Event Name
Event ID
Event Class
Mask
AUE_UTSSYS
233
ad
0x00000800
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-156 vfork(2)
Event Name
Event ID
Event Class
Mask
AUE_VFORK
25
pc
0x00000080
Format:
header-token
argument-token      (0, "child PID", pid)
subject-token
	return-token
The fork return values are undefined because the audit record is
Table A-157 vtrace(2)
Event Name
Event ID
Event Class
Mask
AUE_VTRACE
36
pc
0x00000080
Format:
header-token
	subject-token
return-token
Table A-158 xmknod(2)
Event Name
Event ID
Event Class
Mask
AUE_XMKNOD
240
fc
0x00000010
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
Table A-159 xstat(2)
Event Name
Event ID
Event Class
Mask
AUE_XSTAT
235
fa
0x00000004
Format:
header-token
	path-token
	[attr-token]
	subject-token
	return-token
