The arg token contains system call argument information: the argument number of the system call, the augment value, and an optional descriptive text string. This token allows a 32-bit integer system-call argument in an audit record. The arg token has 5 fields: a token ID that identifies this token as an arg token, an argument ID that tells which system call argument the token refers to, the argument value, the length of a descriptive text string, and the text string. Figure A-4 shows the token form.
