The ipc token contains the System V IPC message/semaphore/shared-memory handle used by the caller to identify a particular IPC object. This token has three fields: a token ID that identifies this as an ipc token, a type field that specifies the type of the IPC object, and the handle that identifies the IPC object. Figure A-14 shows an ipc token.
The IPC object identifiers violate the context-free nature of the Solaris CMW audit tokens. No global "name" uniquely identifies IPC objects; instead, they are identified by their handles, which are valid only during the time the IPC objects are active. The identification should not be a problem since the System V IPC mechanisms are seldom used and they all share the same audit class.
The IPC object type field can have the values shown in Table A-4. The values are defined in /usr/include/bsm/audit.h.
Table A-4 IPC Object Type Field
Name |
Value |
Description |
AU_IPC_MSG |
1 |
IPC message object |
AU_IPC_SEM |
2 |
IPC semaphore object |
AU_IPC_SHM |
3 |
IPC shared memory object |
