SunSHIELD Basic Security Module Guide
path Token
The path token contains access path information for an object. The token contains a token ID and the absolute path to the object based on the real root of the system. The path has the following structure: a byte count of the path length and the path. Figure A-19 shows a path token.
Figure A-19 path Token Format
Graphic
