SunSHIELD Basic Security Module Guide
Audit Daemon's Role
The following list summarizes what the audit daemon, auditd, does.
When the audit daemon starts as the machine is brought up to multiuser mode, or when the audit daemon is instructed by the audit -s command to reread the file after the file has been edited, auditd determines the amount of free space necessary and reads the list of directories from the audit_control file. It then uses those directories as possible locations for creating audit files.
The audit daemon maintains a pointer into this list of directories, starting with the first. Every time the audit daemon needs to create an audit file, it puts the file into the first available directory in the list, starting at the audit daemon's current pointer. The pointer can be reset to the beginning of the list if the administrator enters the audit -s command. When you use the audit -n command to instruct the daemon to switch to a new audit file, the new file is created in the same directory as the current file.
