SunSHIELD Basic Security Module Guide
Example audit_control File Entries
When you add the dir: entries in the audit_control file, make sure the full path down to the files subdirectory is specified. The following example shows an audit_control file dir: entry for the server blinken, which is storing its audit files on its own local disk.
# cat /etc/security/audit_control
dir:/etc/security/audit/blinken.1/files
dir:/etc/security/audit/blinken.2/files
