SunSHIELD Basic Security Module Guide
Definitions of Audit Flags
Each predefined audit class is shown in Table 2-2 with the audit flag (which is the short name that stands for the class), the long name, a short description, and a longer definition. The system administrator uses the audit flags in the auditing configuration files to specify which classes of events to audit. Additional classes can be defined and existing classes can be renamed by modifying the audit_class file (see the audit_class(4) man page).
Table 2-2 Audit Classes
Short Name
Long Name
Short Description
no
no_class
Null value for turning off event preselection
fr
file_read
Read of data, open for reading, and so forth
fw
file_write
Write of data, open for writing, and so forth
fa
file_attr_acc
Access of object attributes: stat, pathconf, and so forth
fm
file_attr_mod
Change of object attributes: chown, flock, and so forth
fc
file_creation
Creation of object
fd
file_deletion
Deletion of object
cl
file_close
close system call
pc
process
Process operations: fork, exec, exit, and so forth
nt
network
Network events: bind, connect, accept, and so forth
ip
ipc
System V IPC operations
na
non_attrib
Nonattributable events
ad
administrative
Administrative actions
lo
login_logout
Login and logout events
ap
application
Application-defined event
io
ioctl
ioctl system call
ex
exec
Program execution
ot
other
Miscellaneous
all
all
All flags set
