Occasionally, if an audit daemon dies while its audit file is still open, or a server becomes inaccessible and forces the machine to switch to a new server, an audit file remains in which the end-time in the file name is the string not_terminated, even though the file is no longer used for audit records. When such a file is found, you can manually verify that the file is no longer in use and clean it up by specifying the name of the file with the correct options.
# auditreduce -O machine 19870413120429.not_terminated.machine |
This creates a new audit file with the correct name (both time stamps), the correct suffix (machine, explicitly specified), and copies all the messages into it.
