SunSHIELD Basic Security Module Guide
How auditreduce Helps in a Distributed System
When multiple machines running Solaris BSM are administered as part of a distributed system, each machine performs auditable events, and each machine writes audit records to its own machine-specific audit file. This simplifies software and is robust in the face of machine failures.
The auditreduce command makes the job of maintaining the whole audit trail practical. Using auditreduce (or shell scripts you write yourself to provide a higher-level interface), you can read the logical combination of all audit files in the system as a single audit trail, without regard to how the records were generated or where they are stored.
The auditreduce program operates on the audit records produced by the audit daemon. Records from one or more audit files are selected and merged into a single, chronologically ordered output file. The merging and selecting functions of auditreduce are logically independent. auditreduce selects messages from the input files as the records are read, before the files are merged and written to disk. Refer to the auditreduce(1M) man page.
