Writing Device Drivers
Disk I/O Controls
Sun disk drivers need to support a minimum set of I/O controls specific to Sun disk drivers. These I/O controls are specified in the dkio(7) manual page. Disk I/O controls transfer disk information to or from the device driver. In the case where data is copied out of the driver to the user, ddi_copyout(9F) should be used to copy the information into the user's address space. When data is copied to the disk from the user, the ddi_copyin(9F) should be used to copy data into the kernels address space. Table G-1 lists the mandatory Sun disk I/O controls.
Table G-1 Mandatory Sun Disk I/O Controls
I/O Control
Description
DKIOCINFO
Returns information describing the disk controller.
DKIOCGAPART
Returns a disk's partition map.
DKIOCSAPART
Sets a disk's partition map.
DKIOCGGEOM
Returns a disk's geometry.
DKIOCSGEOM
Sets a disk's geometry.
DKIOCGVTOC
Returns a disk's Volume Table of Contents.
DKIOCSVTOC
Sets a disk's Volume Table of Contents.
