Writing Device Drivers
Instance Numbers
The system assigns an instance number to each device. The driver may not reliably predict the value of the instance number assigned to a particular device. The driver should retrieve the particular instance number that has been assigned by calling ddi_get_instance(9F), as shown in Example 5-4.
Instance numbers are derived in an implementation-specific manner from different properties for the different device types. The following properties are used to derive instance numbers:
Persistent Instances
Once an instance number has been assigned to a particular physical device by the system, it stays the same even across reconfiguration and reboot. Because of this, instance numbers seen by a driver may not appear to be in consecutive order.
