int devo_rev; int devo_refcnt; int (*devo_getinfo)(dev_info_t *dip,ddi_info_cmd_t infocmd, void *arg, void **result); int (*devo_identify)(dev_info_t *dip); int (*devo_probe)(dev_info_t *dip); int (*devo_attach)(dev_info_t *dip, ddi_attach_cmd_t cmd); int (*devo_detach)(dev_info_t *dip, ddi_detach_cmd_t cmd); int (*devo_reset)(dev_info_t *dip, ddi_reset_cmd_t cmd); int (*devo_power)(dev_info_t *dip, int component, int level); struct cb_ops *devo_cb_ops; struct bus_ops *devo_bus_ops;
The dev_ops(9S) structure allows the kernel to find the autoconfiguration entry points of the device driver. The devo_rev field identifies the revision number of the structure itself, and must be set to DEVO_REV. The devo_refcnt field must be initialized to zero. The function address fields should be filled in with the address of the appropriate driver entry point. Exceptions are:
If a probe(9E) routine is not needed, use nulldev(9F).
identify(9E) is obsolete and no longer required. Set this field to nulldev(9F).
Use nodev(9F) in devo_detach to prevent the driver from being unloaded.
Set devo_reset to nodev(9F).
Drivers for devices that provide Power Management functionality must have a power(9E) entry point. If a power(9E) routine is not needed, set this field to NULL.
The devo_cb_ops member should include the address of the cb_ops(9S) structure. The devo_bus_ops field must be set to NULL.
