Most character drivers use physio(9F) to do most of the setup work for DMA transfers in read(9E) and write(9E). This is shown in Example 9-5.
int physio(int (*strat)(struct buf *), struct buf *bp, dev_t dev, int rw, void (*mincnt)(struct buf *), struct uio *uio);
physio(9F) requires the driver to provide the address of a strategy(9E) routine. physio(9F) ensures that memory space is locked down (cannot be paged out) for the duration of the data transfer. This is necessary for DMA transfers because they cannot handle page faults. physio(9F) also provides an automated way of breaking a larger transfer into a series of smaller, more manageable ones. See "minphys(9F)" for more information.
static int xxread(dev_t dev, struct uio *uiop, cred_t *credp) { struct xxstate *xsp; int ret; xsp = ddi_get_soft_state(statep, getminor(dev)); if (xsp == NULL) return (ENXIO); ret = physio(xxstrategy, NULL, dev, B_READ, xxminphys, uiop); pm_idle_component(xsp->dip, 0); return (ret); } static int xxwrite(dev_t dev, struct uio *uiop, cred_t *credp) { struct xxstate *xsp; int ret; xsp = ddi_get_soft_state(statep, getminor(dev)); if (xsp == NULL) return (ENXIO); ret = physio(xxstrategy, NULL, dev, B_WRITE, xxminphys, uiop); pm_idle_component(xsp->dip, 0); return (ret); }
In the call to physio(9F), xxstrategy() is a pointer to the driver strategy routine. Passing NULL as the buf(9S) structure pointer tells physio(9F) to allocate a buf(9S) structure. If it is necessary for the driver to provide physio(9F) with a buf(9S) structure, getrbuf(9F) should be used to allocate one. physio(9F) returns zero if the transfer completes successfully, or an error number on failure. After calling strategy(9E), physio(9F) calls biowait(9F) to block until the transfer is completed or fails. The return value of physio(9E) is determined by the error field in the buf(9S) structure set by bioerror(9F).
