Writing Device Drivers
Changes to Routines
The reason the rules are so stringent is that the implementation will change. If driver routines follow these rules, they will not be affected by changes to the implementation. If, however, they assume that the autoconfiguration routines are called only in a certain order (first probe(9E), then attach(9E), for example), these drivers will break in some future release.
