The driver could accidentally wait for an event that will never occur, or the event might not happen for a long time. In either case, the user might want to abort the process by sending it a signal (or typing a character that causes a signal to be sent to the process). Whether the signal causes the driver to wake up depends upon the driver.
In the SunOS 4.1 system, whether the sleep()() was signal-interruptible depended upon the dispatch priority passed to sleep()(). If the priority was greater than PZERO, the driver was signal-interruptible, otherwise the driver would not be awakened by a signal. Normally, a signal interrupt caused sleep( ) to return to the user, without notifying the driver that the signal had occurred. Drivers that needed to release resources before returning to the user passed the PCATCH flag to sleep( ), then looked at the return value of sleep() to determine why they awoke:
while (busy) { if (sleep(&busy, PCATCH | (PRIBIO + 1))) { /* awakened because of a signal */ /* free resources */ return (EINTR); } }
In the SunOS 5.7 system, the driver can use cv_wait_sig(9F) to wait on the condition variable, but be signal interruptible. Note that cv_wait_sig(9F) returns zero to indicate the return was due to a signal, but sleep( ) in the SunOS 4.1 system returned a nonzero value:
while (busy) { if (cv_wait_sig(&busy_cv, &busy_mu) == 0) { /* returned because of signal */ /* free resources */ return (EINTR); } }
