The system provides a number of routines that can aid in debugging; these are documented in Section 9 of the Solaris 2.7 Reference Manual.
cmn_err(9F) is used to print messages to the console from within the device driver. cmn_err(9F) provides additional format characters (such as %b) to print device register bits. See cmn_err(9F) and "Printing Messages"for more information.
Though printf() and uprintf() currently exist, they should not be used if the driver is to be Solaris DDI-compliant.
void ASSERT(int expression)
ASSERT(9F) can be used to ensure that a condition is true at some point in the program. It is a macro whose use varies depending upon whether the compilation symbol DEBUG is defined. If DEBUG is not defined, the macro expands to nothing and the expression is not evaluated. If DEBUG is defined, the expression is evaluated and, if the value is zero, a message is printed to the system console and the system panics.
For example, if a driver pointer should be non-NULL and is not, the following assertion could be used to check the code:
ASSERT(ptr != NULL);
If the driver is compiled with DEBUG defined and the assertion fails, a message is printed to the console and the system panics:
panic: assertion failed: ptr != NULL, file: driver.c, line: 56
Because ASSERT(9F) uses DEBUG, it is suggested that any conditional debugging code also be based on DEBUG, rather than on a driver symbol (such as MYDEBUG). Otherwise, for ASSERT(9F) to function properly, DEBUG must be defined whenever MYDEBUG is defined.
Assertions are an extremely valuable form of active documentation.
int mutex_owned(kmutex_t *mp);
A significant portion of driver development involves properly handling multiple threads. Comments should always be used when a mutex is acquired; they are even more useful when an apparently necessary mutex is not acquired. To determine if a mutex is held by a thread, use mutex_owned(9F) within ASSERT(9F):.
void helper(void) { /* this routine should always be called with the mutex held */ ASSERT(mutex_owned(&xsp->mu)); ... }
Future releases of the Solaris operating system may only support the use of mutex_owned(9F) within ASSERT(9F) by not defining mutex_owned(9F) unless the preprocessor symbol DEBUG is defined.
