Machine or kadb(1M) internal registers are identified with the `<` command, followed by the register of interest. On SPARC machines, the following register names are recognized:
dot, the current location |
i0-7 |
Input registers to current function |
o0-7 |
Output registers for current function |
l0-7 |
Local registers |
g0-7 |
Global registers |
psr |
Processor Status Register |
tbr |
Trap Base Register |
wim |
Window Invalid Mask |
For more information on how these registers are normally used, see the System V Application Binary Interface, SPARC Processor Supplement.
On x86 machines, the following register names are recognized:
ebp |
Stack frame base register |
esp |
Stack pointer |
kesp |
Kernel stack pointer |
cs |
Code segment |
ds |
Data segment |
ss |
Stack segment |
eip |
Program pointer or instruction pointer |
efl |
Status flags register |
The remaining examples in this chapter are for use on SPARC machines only. For specific register information relating to x86 machines, see the System V Application Binary Interface, x86 Processor Supplement.
The following command displays the PSR as a 4-byte hexadecimal value:
kadb[0]: <psr=X 400cc3
