adb(1) and kadb(1M) support macros. adb(1) macros are in /usr/lib/adb and /usr/platform/`uname -i`/lib/adb for 32-bit programs and in /usr/lib/adb/sparcv9 and /usr/platform/`uname -i`/lib/adb/sparcv9 for 64-bit programs. kadb(1M) macros are builtin and can be displayed with $M. Most of the existing macros are for private kernel structures. New macros for adb can be created with adbgen(1M).
Macros are used in the form:
[ address ] $<macroname
threadlist is a useful macro that displays the stacks of all the threads in the system. Because this macro does not take an address and can generate excessive output, be ready to use Control-S and Control-Q to start or stop if necessary--this is another good reason to use a tip window. Control-C can be used to abort the listing.
kadb[0]: $<threadlist ============== thread_id f0244020 p0: p0: process args= sched t0: t0: lwp proc wchan f02a3e78 f02a8078 0 t0+0x34: sp pc f0243af0 sched+0x4e0 ?(?) + 0 main(0x0,0xf02b7e20,0xf02a800c,0x0,0x6e,0x0) afsrbuf(?) + 1b8 exitto(0xf0040000,0xf02a0f58,0x3c,0xf02d3c40,0xfbd7d668,0x0) ============== thread_id fbe01ea0 p0: p0: process args= sched 0xfbe01ea0: lwp proc wchan 0 f02a8078 0 0xfbe01ed4: sp pc fbe1fe68 debug_enter+0xb0 ?(?) + 0 abort_sequence_enter(0x0,0x740000,0xc4,0x0,0x0,0x40000e7) zsa_xsint(0xf5dd9000,0x80,0xf5dd906c,0x44,0xff0113,0x0) + 244 zs_high_intr(0xf5dd9000) + 204 _level1(0x0) + 13bc idle(0xf02a0fac,0x0,0xf02a8078,0xf02a8078,0xf004684c,0x4400ae1) + 50 ============== thread_id fbe22ea0 p0: p0: process args= sched 0xfbe22ea0: lwp proc wchan 0 f02a8078 f5caf024 0xfbe22ed4: sp pc fbe22d80 cv_wait+0x64 ?(?) + 0 cv_wait(0xf5caf024,0xf5caf010,0xffdf1175,0x6ea7e,0xf5caf030,0x40000000) callout_thread(0xf5caf010,0xf5caf024,0xf02a8078,0xf02a8078,0x1000,0x4400ae5)+38 ...
Another useful macro is thread. Given a thread ID, this macro prints the corresponding thread structure. This can be used to look at a certain thread found with the threadlist macro, to look at the owner of a mutex, or to look at the current thread.
kadb[0]: <g7$<thread 0xfbe01ea0:0xfbe01ea0: link stk startpc bound 0 fbe01e40 f0076d40 f02a0fac 0xfbe01eb0: affcnt bind_cpu flag procflag 1 -1 8 0 0xfbe01eb8: schedflag preempt preempt_lk state 3 1 0 4 0xfbe01ec0: pri epri pc sp -1 0 f005bdf8 fbe1fe68 0xfbe01ecc: wchan0 wchan sobj_ops cid 0 0 0 0 0xfbe01edc: clfuncs cldata ctx lofault f02aeed8 0 0 0 0xfbe01eec: onfault nofault swap lock 0 0 fbe01000 ff 0xfbe01efa: delay_cv cpu intr did 0 f02a0fac 0 1 0xfbe01f08: tnf_tpdp tid alarmid f5a75c80 0 0 realitimer 0xfbe01f14: interval.sec interval.usec value.sec value.usec 0 0 0 0 0xfbe01f24: itimerid sigqueue sig 0 0 0 0 0xfbe01f34: hold forw back 0 0 0 0 0xfbe01f44: lwp procp next prev 0 f02a8078 fbe04ea0 f0244020 0xfbe01f58: trace why what dslot pollstate 0 0 0 0 0 0xfbe01f68: cred lbolt sysnum pctcpu 0 0 0 0 0xfbe01f88: lockp oldspl pre_sys disp_queue f02a1014 e0 0 f02a0ff0 ...
No type information is kept in the kernel, so using a macro on an inappropriate object results in garbage output.
Macros do not necessarily output all the fields of the structures, nor is the output necessarily in the order given in the structure definition. Occasionally, memory may need to be dumped for certain structures and then matched with the structure definition in the kernel header files.
Drivers should never reference header files and structures not listed in Section 9S of the Solaris 2.7 Reference Manual. However, examining non-DDI-compliant structures (such as thread structures) can be useful in debugging drivers.
