Writing Device Drivers
Saving System Core Dumps
When the system panics, it writes the memory image to the dump device. The dump device by default is the primary swap device. The dump is a system core dump, similar to core dumps generated by applications. On rebooting after a panic, savecore(1M) checks the dump device for a crash dump. If one is found, it makes a copy of the kernel that was running (called unix.n) and dumps a core file (called vmcore.n) in the core image directory which by default is /var/crash/machine_name.
In Solaris 7, crash dump is enabled by default. The dumpadm(1M) command is used to configure system crash dumps. The dumpadm(1M) command should be used to verify that crash dumps are enabled and to determine the location of the directory where core files are saved. See dumpadm(1M) for more information.
Note -
dumpadm(1M) should be used to verify that the system is correctly configured for obtaining crash dumps.
When savecore(1M) runs, it makes a copy of the kernel that was running (called unix.n) and dumps a core file (called vmcore.n) in the specified directory, normally /var/crash/machine_name. There must be enough space in /var/crash to contain the core dump or it will be truncated. Because the file contains holes, it will appear larger than actual size; avoid copying it. adb(1) can then be used on the core dump and the saved kernel.
Note -
savecore(1M) can be prevented from filling the file system if there is a file called minfree in the directory in which the dump will be saved. This file contains a number of kilobytes to remain free after savecore(1M) has run. However, if not enough space is available, the core file is not saved.
