Writing Device Drivers
In kadb(1M), breakpoints can be set that will automatically drop back into kadb when reached. The standard form of a breakpoint command is:
	[module_name#] addr [, count]:b [command]
addr is the address at which the program will be stopped and the debugger will receive control, count is the number of times that the breakpoint address occurs before stopping, and command is almost any adb(1) command.
The optional module_name specifies deferred breakpoints that are set when the module is loaded. module_name identifies a particular module that contains addr. If the module has been loaded, kadb will try to set a regular breakpoint; if the module is not loaded, kadb will set a deferred breakpoint. When the module is loaded, kadb will try to resolve the location of the breakpoint and convert the breakpoint to a regular breakpoint.
Other breakpoint commands are:
Continue execution
Delete breakpoint
Single step
Single step, but step over function calls
Stop after return to caller of current function
Delete all breakpoints
The following example sets a breakpoint in scsi_transport(9F), a commonly used routine. Upon reaching the breakpoint, `$c' is used to get a stack trace. The top of stack is the first function printed. Note that kadb(1M) does not know how many arguments were passed to the function; it always prints six.
kadb[0]: scsi_transport:bkadb[0]: :c
 test console login: root
  breakpoint at:
  scsi_transport: save    %sp, -0x60, %sp
  kadb[0]: $c
  sdstrategy(0xf5d4b8a8,0xf5ad0e1c,0x0,0x2c1d0,0xf5ad0d78,0x0) + 3c0
  bdev_strategy(0xf5d4b8a8,0xf5cd3dcc,0x8,0x40,0xf0319e60,0x1000) + d0
  ufs_getpage_miss(0x0,0xf6133840,0x0,0x0,0xfbecb8e8,0x1) + 23c
  ufs_getpage(0x0,0x1000,0x0,0x0,0x0,0x1) + 640
  segmap_fault(0xf5b34000,0xf5d76f98,0x0,0x1000,0x0,0x1) + 120
  segmap_getmapflt(0xf0ba4000,0xf0ba4000,0x10000,0x0,0x6c267,0x0) + 4b0
  rdip(0xf61337b8,0x0,0xf6133840,0xf5a74938,0x0,0xf5cda000) + 328
  ufs_read(0xf61338a4,0xfbecbaf0,0x0,0xf5a74938,0xf5ca7e80,0xf61337b8) + 118
  read(0x4) + 274
  syscall_trap(?) + 18c
  Syssize(0x4) + d3c0
  Syssize(0x26ad4,0x27400,0x0,0xef66855c,0xef661f58,0x11e78) + d2bc
  Syssize(0x27b88,0x27400,0xeffffe74,0x26968,0x27f94,0x27a84) + bc28
  kadb[0]: :s
  stopped at:
  scsi_transport+4:               mov     %i0, %i1
  kadb[0]: $b
  count   bkpt            type      len   command
  1       scsi_transport  :b instr  4
  kadb[0]: scsi_transport:d
  kadb[0]: :c
