Writing Device Drivers
Preparing for Disasters
It is possible for a driver to render the system incapable of booting. To avoid system reinstallation in this event, some advance work must be done.
Critical System Files
A number of driver-related system files are difficult, if not impossible, to reconstruct. Files such as /etc/name_to_major,/etc/driver_aliases, /etc/driver_classes, and /etc/minor_perm can be corrupted if the driver crashes the system during installation (see add_drv(1M)).
To be safe, once the test machine is in the proper configuration, make a backup copy of the root file system. If you plan on modifying the /etc/system file, make a backup copy of the file before modifying it.
Booting an Alternate Kernel
A kernel other than /platform/`uname -i`/kernel/unix can be booted by specifying it as the boot file. In fact, backup copies of all the system drivers in /platform/* can be made and used if the original drivers fail (this is probably more useful if more than one driver is being debugged). For example:
# cp -r /platform/sun4c/kernel /platform/sun4c/kernel.orig
To boot the original system, boot kernel.orig/unix.
Note -
During testing, the new driver should be placed in /platform/sun4c/kernel (and not in /kernel or /usr/kernel) so that, the driver is not loaded if the system is booted out of kernel.orig. Alternatively, the module path can be changed by booting with the ask (-a) option.
ok boot kernel.orig/unix
Rebooting with command: kernel.orig/unix
Boot device: /sbus/esp@0,800000/sd@1,0   File and args:kernel.orig/unix
SunOS Release 5.7 Version Generic [UNIX(R) System V Release 4.0]
Copyright (c) 1983-1998, Sun Microsystems, Inc.
For more complete control, boot with the ask (-a) option; this allows alternate boot parameters to be specified (such as /dev/null or /etc/system.orig if that is the saved original system file that was copied earlier).
ok boot -a
Rebooting with command: disk1 -a
Boot device: /sbus/esp@0,800000/sd@1,0   File and args: -a
Enter filename [/kernel/unix]: kernel.orig/unixEnter default directory for modules
[/platform/SUNW,Sun_4_75/kernel.orig /kernel /usr/kernel]:<CR>SunOS Release 5.7 Version Generic [UNIX(R) System V Release 4.0]
Name of system file [etc/system]: etc/system.origroot filesystem type [ufs]: <CR>Enter physical name of root device
[/sbus@1,f8000000/esp@0,800000/sd@1,0:a]: <CR>
Booting Off the Network or CD-ROM
If the system is attached to a network, the test machine can be added as a client of a server. If a problem occurs, the system can be booted off the network. The local disks can then be mounted and fixed. Alternatively, the system can be booted directly from the Solaris 7 CD-ROM.
Re-creating /devices and /dev
If the /devices or /dev directories are damaged--most likely to occur if the driver crashes during attach(9E))--they may be recreated by booting the system and running fsck(1M) to repair the damaged root file system. The root file system can then be mounted and /devices re-created by running drvconfig(1M) and specifying the /devices directory on the mounted disk. The /dev directory can be repaired by running devlinks(1M), disks(1M), tapes(1M), and ports(1M) on the dev directory of the mounted disk.
On SPARC, for example, if the damaged disk is /dev/dsk/c0t3d0s0, and an alternate boot disk is /dev/dsk/c0t1d0s0, do the following:
ok boot disk1
# fsck /dev/dsk/c0t3d0s0** /dev/dsk/c0t3d0s0
** Last Mounted on /
** Phase 1 - Check Blocks and Sizes
** Phase 2 - Check Pathnames
** Phase 3 - Check Connectivity
** Phase 4 - Check Reference Counts
** Phase 5 - Check Cyl groups
1478 files, 9922 used, 29261 free(141 frags, 3640 blocks, 0.4% fragmentation)
# mount /dev/dsk/c0t3d0s0 /mnt# drvconfig -r /mnt/devices# devlinks -r /mnt# disks -r /mnt# tapes -r /mnt# ports -r /mnt
Caution - Caution -
Fixing /devices and /dev may allow the system to boot, but other parts of the system may still be corrupted. This may only be a temporary fix to allow saving information (such as system core dumps) before reinstalling the system.
Booting Off a Backup Root Partition
One way to recover from disaster is to have another bootable root file system. Use format(1M) to make a partition the exact size of the original, then use dd(1M) to copy it. After making a copy, run fsck(1M) on the new file system to ensure its integrity.
Later, if the system cannot boot from the original root partition, boot the backup partition and use dd(1M) to copy the backup partition onto the original one. If the system will not boot but the root file system is undamaged (just the boot block or boot program was destroyed), boot off the backup partition with the ask (-a) option, then specify the original file system as the root file system.
